08-19-2011 08:18 AM - edited 07-03-2021 08:36 PM
I have some clients running Vista on an HP laptop with a b/g card that has issues connecting to a 3502. I am able to connect but traffic does not pass. I can with the same client connect to a 1142. Both AP's are Lightweight and connected to the same controller. Authentication is PEAP - WPA2. Anyone else have this issue?
08-19-2011 07:11 PM
1. Are you using AP Groups?
2. What firmware is your WLC running?
3. Does the HP client get a valid IP address?
4. What logs do you get when this happens?
09-15-2011 02:03 PM
I just ran into the same issue and haven't found a solution. The user can connect to 1131's and 1142's without a problem, but can't connect to any of our 3502's using WPA (802.1X). The user is able to see the signal from the access point and even communicate through it when authenticating via Web-Auth, just not when using WPA 802.1X.
This happens regardless of which controller the access point is on (we have two). Both controllers are running 7.0.116.0. The laptop doesn't show up on the controller at all when attempting to connect on a 3502.
09-15-2011 03:19 PM
Hello Rudy, Terrance,
Sounds like it's time to capture a client debug when the device attempts to connect to the 3500 AP.
From the WLC CLI, capture the output:
debug client xx:xx:xx:xx:xx:xx
(where xx:xx... is the wireless mac address for the client device). We can then take a look at why this connection is failing.
-Patrick Croak
Wireless TAC
09-15-2011 04:36 PM
What drivers are the clients using? Sounds like the supplicant/driver is nit ling the packets from the AP when using encryption
