06-21-2013 03:04 AM - edited 07-04-2021 12:16 AM
Does anybody know what is the maximum number of associated clients that supports a 1552I?
Has anybody tried with simultaneous streaming of multiple clients, how many will run?
Solved! Go to Solution.
06-21-2013 04:21 AM
Well the limit is 200 and that's a configuration limit on the WLC code for AP's. Now how many on the mesh really depends on how many MAP's to RAP's you have as the backhaul is shared. For indoors it's typically 25 which is a good number and works well for outdoor, but I have had 100+ on a MAP at a high school sporting event and you really can't control that as your not going to deploy high density.
06-21-2013 04:21 AM
