Hi all,
I have been facing roaming issue where solution Client -based ( High Density AP deployment). All AP's are in flexgroup and authentication method is 802.1x.
I have customised the RF environment with RF profiles( power level max 17dbm for both the bands)
Global Roaming parameters -67dbm, Hystersis -3db and scan threshold -62dbm.
Datarates are disabled till 11 mbps.
Still clients are getting connected to far away AP's .I could see the signal strength is good enough where clients wont decide to roam. If I disable data rates up to 18mbps or 24mbps for both the bands. Do clients disconnect if they are getting lower datarates or will roam to nearby AP's .?/
Will RxSOP help in this issue with code 8.0???? and if I configure optimized roaming with value -67dbm will clients get kicked off by AP ??
Warm Regards
Sri
