RP -TNC to N-Type
naveed.khawar
Dear Sir,
[1] Plesae advise me how to connect LMR900 cable which has N-type male connectors on either end to Cisco 1. Antenna AIR-CAB050LL-R and 2. Access Point AIR-BR1310G-A-K9-R.
Your urgent reply shall be appreciated.
Thank you,
beth-martin
Level 5
Level 5
I am not sure if there are any convertors available for this. What are you trying to accomplish with this?
sorvarit
From the BR1310 to the LMR900 cable you need a RP-TNC plug to N female pigtail. Theese you should get from many vendors. RP-TNC jack to N female converter or pigtail you should probaly use at the antenna.
http://www.hyperlinktech.com/web/connectors/adapters.php
Orjan
Hi Orjan,
The subject issue is resolved.
Thank you for your Kind support.
Best Regrads
