Upgrading 1252s from autonomous to LWAPP
kristin.knight
I need to upgrade several 1252s from autonomous to LWAPP.
I have not been able to find the upgrade tool for 1250s or instructions for CLI upgrade.
I wil be using NCS to do final configuration once the APs come online.
Can someone assist?
Kristin
Stephen Rodriguez
So long as you pull the rcv file for the AP you should be able ti use NCS to do the conversion.
Other than that a standard AP upgrade should work, with the rcv file as well.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
