WAP561 reboot on connect
MarkSpoon
I have 6 WAP561 Access Points. One of them will reboot after i connect it on my POE Switch.
I have resettet the system, i have changed in a new system but nothing helped. i don´t know what can i do. It is new and resettet to factory defaults but if i connect and power on, one minute later it will reboot. The website of the access point is 30 seconds up.
The 5 WAP561 are in singlePoint setup and i need this one too.
Any help or ideas?
Brandon Buffin
Does the switch have enough available power? If you use a power adapter does the WAP stay up?
Brandon
