We have some rolling carts used for telemedicine and are currently using Linksys WET610N wireless bridges. I haven't been very impressed with them - I have to reboot them at least once a week and figure it's a roaming issue. Since they are a residential product they probably weren't designed to do a lot of roaming.
I started playing around with WGB and setup an 1142 AP and got it to work. Unfortunately, the only place I can put the AP is inside the cart and the metal top seems to be interfering with the wireless signal.
Which Cisco indoor APs have external antennae mounts and are capable of performing as a WGB?
Our infrastructure is 4400 controllers and 1142 APs.
Thanks.
