Camera Archiving With Motion Detection
csco10971283
Dears,
I configured recording with motion detection on VSOM 6.3.2 but I think the recording is not working properly.
I can't find all the actions happened in the archiving.
Can anybody tell me step-by-step configuration for the archiving with motion detection.
Ahmed Ossama
Ahmed Ossama
CCIE#26611
csco10971283
Dears,
Hope any one can reply to me...
Ahmed Ossama
Ahmed Ossama
CCIE#26611
Hello Ahmed,
Thank you for posting your question on Cisco Support Community forums.  A colleague of mine posted an excellent guide to creating motion archives which you may find in the Documents section of CSC (direct link posted below.)
https://supportforums.cisco.com/docs/DOC-15088
As a rule, for the 24xx, 25xx and 26xx Cisco cameras, it is best to configure the smallest motion windows possible which still guarantee coverage of the area of interest (middle of a door for example rather than the entire wall containing the door.)  You are permitted up to 4 motion windows per camera on the above mentioned models.
I hope that helps,
Jim
