Defective Cameras?
Ivan Villagomez
just received 12 cameras Cisco 2600 and 2 4500 after initial testing on a 3750X ( all on the same port gi1/0/9) out of the 12 cameras 2600 5 cameras cannot power on, the switch is sending a power Tstart error detected.
Can it be possile to receive so many defective cameras? Or do you have any info on this problem?
kcapoor
Ivillagomez,
Did you try resetting those camera , also try to power them up directly with adapter.
Karan Capoor
PDI-HD
sfeldmann
I had a similar issue with some 5011 cameras I was working on at my desk.  I didn't troubleshoot it much, but there appears to be something going on if the same switch port is used and different cameras are tried 1 after the other.  Since I had a switch at my desk, I just changed ports, and the camera powered on.  I was using a 3750G w/ POE.
