04-08-2011 05:37 AM
Hi ,
I have a problem in connecting VSMS & SAN (EMC Clariion CX4 )
They are connected via fiber cable ( LC , multi-mode )
If I rebooted the VSMS server and the fiber cable connected , the server doesn't start again till the fiber cable is removed .
Can anyone help solving this problem ?
Thanks .
04-08-2011 07:44 AM
Can you please supply the following informaton so I can look into this for you?
Thank you,
Sean
04-08-2011 09:55 AM
CIVS-MSP-4RU
1*FC card ( CIVS-FC-1P) ( no analog encoders )
started after connecting the fiber cable
in the field
Suse Linux , 10 SP1
6.3.1
04-12-2011 09:14 AM
The card is supposed to be installed at the factory. However, can you please send me the following file from your server:
/etc/sysconfig/kernel
Thank you,
Sean
