Issues with upgrade to 6.3.2
dean-lamb
We recently upgraded from 6.3.1 to 6.3.2 and I have a server, it is running VSMS, VSOM, and now the rights and permissions in the roles on this server seem to have gone into crazy mode.  Randomly user had the ability to view cameras and groups of cameras and archives they never did and some clients can't use the fast forward tools in the archive play back.  This is a huge problem when an event happens and you have to watch 1 to 2 hours of video and you only can watch in regular speed.  The other 3 servers seem to have no issues and run fine.  Every since the upgrade and the rights issues, the primary server I am speaking of has started to run extremely slow.  Any Ideas?
Thanks for any help.  I am still learning the system and this may be something simple but I just can't get my head around it.
mcwalter
Level 3
Level 3
Hi Dean,
How full is the OS partition on the server? If it is full you will see all sorts of funky stuff.
Here is one of ours. its 60% and runs fine. This is a lab server.
linux-gahf:~ # df -h
Filesystem            Size  Used Avail Use% Mounted on
/dev/sda2              11G  6.0G  4.1G  60% /
udev                  507M  124K  506M   1% /dev
/dev/sda1             102M   40M   63M  39% /boot
/dev/sda4             8.9G  8.2M  8.9G   1% /media0
linux-gahf:~ #
Good luck.
Thanks a million.  I will check this and let you know.
