ACS configuration on switches and routers
johnisccp
I have 12 routers and 23 switches that I need to ACS to manage. Is there a quick way to deploy AAA on all the switches and routers instead of going in each one and configure it? I am new to ACS, so any help on how to configure would be great.
rochopra
Through ACS you cannot push AAA config on all devices, you either have to enter it manually or use some NMS software like CiscoWorks to push the config to the devices.
~Rohit
