The project was simple, stack many switches on rack, however, what is the maximum number of racks units with a default stack cable?
We have seen 6 rack units are the maximum, but it is too tight, so I think the maximum actually should be only 5 rack units.
this picture has 6 units racks
13 Comments
balaji.bandi
if the question stacking cable, you need to get maximum cable length that is 3 meter ?
Leo Laohoo
I would be very careful deploying a stacking cable that way.
I had a stack master crash (6 x 9300) after one of the stacking cables became lose.
IOS-XE stacked switches suffer from several memory-leak bug with the stack-mgr daemon.
If we order stacking cables, it will always be 1 metre.
normally stack can go up to 8 switches. if you making big stacks, make sure to get stack cables with enough length. you need 3m cable for patch 1st and last of stack
Leo Laohoo
Officially, 9300/9300L/9300X can support up to 8 switches in a stack.
Unofficially, it can support up to 16 switches in a stack.
balaji.bandi
sure , what a night mare to manage 16switches.
had hardest time with 8 stack 3750 replace and split them to 4 moving forward Cat 9K
deploying a chassy will be easier than managing 16 devices stack...
balaji.bandi
cost ?
mmm. thats kind of thing to think
I dont have this written but previous project I developed with Cisco , they recommend maximum 4 switches per stack. It makes much sense for me for two reason:
Cable lengh
Vlan domain size:  4 switch represents around 250 ports and this is the size of one vlan /24. One IP per device. More or less.  /24 is a very good size for a broadcast domain.
d.cantele1
Just because you can isn't always good that you should...
SROD
Is it me, or are there (6) rack units of space between those (2) switches?
rdvv
It looks good
sherryvar
For a switch stack of 8 devices, the below stacking order with the default stack cable length would be possible [S: Switch ; P: Stack port] [cabling from P1 to P2 based on color]
Welcome to the Project Gallery!
This is a place for Cisco customers and partners to share stories about their technology projects.
Use the comment section to ask a question, make a suggestion or just say well done. If you like a project, thank the author by clicking the Helpful button at the end of the post!
Did you complete a deployment recently? Share your great work with fellow community members! No project is too big or too small.
