Cisco duo security
susim
Level 3
Level 3
I was trying to enable 2fa for anyconnect users based on the link below .
but the user never get a code or push back from duo cloud
1 ) how to trouble shoot the issue .
I can reach the duo cloud ip’s
2 is it possible to do with proxy
  1. Is it possible to login with token only like RSA
ashok123
Dear Susim,
I am ashok and very happy to to meet you , I want to get  the documentation regarding cisco Duo implementation from you , if it is possible could you please share with me the document (or) if not possible that also i can understand , why because i am going to implemet DUO in my organization .
This is my mail ID (ashok.r@nipun.net) so you can send to this mail
Thanks & Regards,
Ashok Kumar
DuoKristina
@ashok123
All our documentation is available online at duo.com.
https://duo.com/docs/cisco links to multiple sets of Duo instructions for Cisco ASA and FirePower VPN. We recommend using SSO for the best user experience, but we also support RADIUS.
Duo, not DUO.
