Duo certificate proxy server problem
mihanowa1
We have deployed duo certificate proxy in our environment. But this impact our own CA server that provide certificate to other service. Our company’s applications can’t take certificate from our root CA because of duo certificate proxy. How can we handle this problem. Is it possible to use our company root certificate instead of certificate taken from duo cloud service for trusted device? If possible how to do it?
Thanks for your attention. I’m looking forward to your reply.
Dooley
Level 3
Level 3
Hi there, after discussing this internally we think it would be best for you to contact our Support Team for some in-depth troubleshooting. There should not be a conflict between the Trusted Endpoints certificate proxy and your own CA, so we recommend working with support on this.
Thank you for your reply.
