Bookmark
Subscribe
1234
DUO Network Gateway Options beside putty
robinson
Level 4
Level 4
All, anyone who has gone through the LONG process of getting the DUO network gateway knows that connecting requires the special configuration of your Client. Cisco’s site shows examples for Windows Git or CYGWIN, MACOS and Linux, and of course putty. Network Engineers live in CLI and many of us prefer to have a fully functional and manageable SSH/Telnet Client (besides PuTTY connection Manager). I use ZOC by EMTEC (https://www.emtec.com/). The EMTEC team created an update to their Terminal product SPECIFICALLY for DUO access via the DUO Network Gateway.
If you use ZOC, you must be running 8.03.2 and above:
First Create a session:
Click Configure next to Connection Type:
Click Override Session Profile Settings, and then click Advanced SSH Settings:
Under the Options Box, and in the Other Options text box, enter the following string, along with the FQDN of your DUO Network Gateway:
-o “ProxyCommand=duoconnect -host %h:%p -relay=https://example.domain.com”
Then Connect to your host.
The secret to succeeding at technology is to say yes you can, and to not be afraid of change. Forget the words, "That's how we always do it"
DuoKristina
@Robinson
Thanks for sharing!
Duo, not DUO.
DuoKristina
@Robinson
Thanks for sharing!
Duo, not DUO.
