ADSL Connection issues
hellspire69_2
Hello all,
I am having issues with two seperate sites. I will post the output below, I am confused though to the bad service we are receiving as the output seems to be fine according to all that I have read. Any second opinions would be brilliant.
Site A.
Modem Status:    Showtime (DMTDSL_SHOWTIME)
DSL Mode:        ITU G.992.1 (G.DMT) Annex A
ITU STD NUM:     0x03                            0x3
Vendor ID:       'STMI'                          'TSTC'
Vendor Specific: 0x0000                          0x0510
Vendor Country:  0x0F                            0xB5
Chip ID:         C196 (0)
DFE BOM:         DFE3.0 Annex A (1)
Capacity Used:   100%                            53%
Noise Margin:    14.5 dB                         22.0 dB
Output Power:    20.0 dBm                        12.5 dBm
Attenuation:     39.5 dB                         22.5 dB
FEC ES Errors:    0                               0
ES Errors:       95                              13
SES Errors:       0                               0
LOSES Errors:     0                               0
UES Errors:       0                               0
Defect Status:   None                            None
Last Fail Code:  None
Watchdog Counter: 0xEB
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction:     0x00
Interrupts:      12480 (0 spurious)
PHY Access Err:  0
Activations:     11
LED Status:      ON
LED On Time:     100
LED Off Time:    100
Init FW:         init_AMR_4.0.018.bin
Operation FW:    AMR-E-4.0.018.bin
FW Source:       external
FW Version:      4.0.18
                 Interleave             Fast    Interleave              Fast
Speed (kbps):          6240                0           448                 0
Cells:                61482                0        233742                 0
Reed-Solomon EC:          0                0             0                 0
CRC Errors:               0                0             0                 0
Header Errors:            0                0             0                 0
Total BER:                0E-0           0E-0
Leakage Average BER:      0E-0           0E-0
                        ATU-R (DS)      ATU-C (US)
Bitswap:               enabled            enabled
Bitswap success:          0                   0
Bitswap failure:          0                   0
Site B
DSL Mode:        ITU G.992.5 (ADSL2+) Annex A
ITU STD NUM:     0x03                            0x2
Chip Vendor ID:  'STMI'                          'IFTN'
Chip Vendor Specific:  0x0000                    0x71C8
Chip Vendor Country:   0x0F                      0xB5
Modem Vendor ID: 'CSCO'                          '    '
Modem Vendor Specific: 0x0000                    0x0000
Modem Vendor Country:  0xB5                      0x00
Serial Number Near:    FCZ10421129
Serial Number Far:
Modem VerChip ID:        C196 (0)
Capacity Used:   95%                             100%
Noise Margin:     8.0 dB                          6.0 dB
Attenuation:     39.0 dB                         20.0 dB
FEC ES Errors:    1                               0
ES Errors:        1                               0
SES Errors:       1                               0
LOSES Errors:     1                               1
UES Errors:       0                              89
Watchdog Counter: 0x95
Watchdog Resets: 0
Subfunction:     0x00
Interrupts:      8299 (0 spurious)
PHY Access Err:  0
Activations:     1
LED Status:      ON
LED On Time:     100
LED Off Time:    100
FW Source:       external
FW Version:      4.0.18
                 DS Channel1      DS Channel0   US Channel1       US Channel0
Speed (kbps):             0             9014             0              1157
Cells:                    0           126169             0          37327987
Reed-Solomon EC:          0              600             0               259
CRC Errors:               0               16             0                32
Header Errors:            0               14             0                10
Total BER:                0E-0           1564E-10
Leakage Average BER:      0E-0           1750E-10
Interleave Delay:         0               52             0                11
Dan
I've deleted my post because someone's has given it a low score.  My findings are correct and true but the low score will be mis-interpreted by other people as an incorrect answer.  This I will not accept.
10 Replies 10
Leo Laohoo
Site "B" noise is not good.
Refer to this document:  http://www.dslreports.com/faq/16220
Thanks for the reply Leo.
I have read the different docs, we are already using the noise-margin 3 command otherwise we would be in even more trouble.
The site is complaining that connections are really really slow. They are only using Citrix and the bandwidth looks fine, would the actual noise cause these issues?
D
hellspire69_2
Thanks for your input Leo its much appreciated.
I hear what you are saying, but I am still perplexed.
What I do not understand is why we get massive spikes in the ping when everything looks ok?
FEC ES Errors:    0                               0
ES Errors:        0                               0
SES Errors:       0                               0
LOSES Errors:     0                               0
UES Errors:       0                               0
Watchdog Counter: 0xD8
Watchdog Resets: 0
Subfunction:     0x00
Interrupts:      4144 (0 spurious)
PHY Access Err:  0
Activations:     1
LED Status:      ON
LED On Time:     100
LED Off Time:    100
FW Source:       external
FW Version:      4.0.18
Speed (kbps):          6976                0           448                 0
Cells:               103799                0        484147                 0
Reed-Solomon EC:         41                0             0                 0
CRC Errors:               0                0             0                 0
Dan,
Have you performed an MTU test?
- Marty
MTU Test?
with only half a meg upload and four + people using the site im wondering if it is more just a over saturation issue really..
Dan,
I agree. Test it with only one PC working and see if you get good results. If yes, try using all four PCs simultaneously and see if you get ping spikes, slow speed, etc. Depending on what the users are doing, half a meg is pretty low for 4 users.
- Marty
SamirD
Level 5
Level 5
I think you're just maxing out the bandwidth, which will result in all sorts of weird things since nothing is made for delays anymore.
If you can limit each computer to 10k/sec, see if that solves the error problem.  If so, then it's just being overloaded.
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
hellspire69_2
I just wanted to say a huge thank you to everyone for all your advice and help.
Dan
