05-02-2017 06:21 AM
Hello everyone,
I'm having some issues with my router. I'm trying to connect it to the internet, I can ping to google.com but on the other hand, when I connect a machine in interface G1, I don't have internet connectivity, I think the problem is in interface g1. I don't understand this router, it has 2 wan ports and 8 L2 ports.
My configuration is below.
Wan Interface G9
Public IP 24.XX.XXX.106
Route 24.XX.XXX.105
DHCP Server 192.168.1.115
R1(config)# interface g9
R1(config-if)# ip address 24.XX.XXX.106 255.255.255.252
R1(config-if)# ip nat outside
R1(config-if)# no shut
R1(config-if)# ip route 0.0.0.0 0.0.0.0 24.XX.XXX.105
R1(config)# interface vlan 1
R1(config-if)# ip address 192.168.1.1 255.255.255.0
R1(config-if)# ip nat inside
R1(config)# interface g1
R1(config-if)# switchport mode access
R1(config-if)# switchport access vlan1
R1(config)# access-list 10 permit 192.168.0.0 0.0.0.255
R1(config)# access-list 10 permit 10.0.0.0 0.0.0.255
R1(config)# ip nat inside source list 10 interface g1 overload
R1(config)# interface vlan1
R1(config-if)# ip helper-address 192.168.1.115
05-02-2017 07:56 AM
Hey
hmm why is the NAT set to to G1 , that should be pointing to the G9 as that's the WAN interface
change to
R1(config)# ip nat inside source list 10 interface g9 overload
05-02-2017 08:13 AM
Hi Mark,
You are absolutely right, I'll try that tomorrow morning and I'll let you know if it works.
05-04-2017 05:00 AM
Hi Mark,
Do you think vlan1 and g1 are configured in the correct way?
05-04-2017 05:11 AM
Yes but you shouldn't have to specify access vlan 1 as the port as all layer 2 ports by default are assigned to vlan 1 unless changed
where is your dhcp server is it on 192.168.1.x/24 if it is then the vlan does not require a helper address this is only so packets can switch from broadcast dhcp to unicast dhcp to find a dhcp server in another subnet
your acl is wrong too its /24 subnet in vlan 1 192.168.1.x/24 , your acl is 192.168.0.x for NAT
so in short this below should do it , nat inside on vlan , nat outside on wan , point overload to wan interface and allow vlan subnet to be natted to get to outside public networks
Let me know how that goes
R1(config)# access-list 10 permit 192.168.1.0 0.0.0.255
05-04-2017 06:23 AM
Mark,
I'm gonna try this next Saturday because I can't stop internet know but for sure I'll let you know how it goes.
Thank you very much again.
05-04-2017 06:26 AM
no problem good luck with it
05-06-2017 11:42 AM
Hi Mark,
once again, you were right, it is working!.
Just to remember, I have some ports to forward
Do you think we need ACL as well?
access-list 11 permit tcp
Thank you, I appreciate a lot your help
