08-13-2022 03:55 PM
my question is can i configure LAN port in RV340 as WAN port to use my 3rd ISP as load balancer, where 2 other WAN are already Online.
08-13-2022 11:15 PM
M.
08-14-2022 02:21 AM
i do not believe RV support more than 2 WAN connection. Since GUI has fixed config, you can not add LAN interface in to 3rd connection.
08-14-2022 02:29 PM
on 1st page you can read, this device has several WAN ports the only problem is they are not Gig ports.
how come RV340 lacks this functionality.
i am amazed at Cisco
can anyone suggest any other RV model which can do this at Gig speed ?
08-15-2022 09:29 AM
Your link was for an older mode (RV016). The RV340/345 can do Gigabit speeds:
But, their end-of-life is rapidly approaching (with no security updates after the EOL).
