Cisco 892 fsp
larlid001
I'm trying to configure my router for a classic adsl home network, with internet - modem - router 892 with builtin switch.
It's Ciscos builtin switch which confuses me, I think...
I have a working outside wan interface (gi8) to my modem (While logged into the router I'm able to traceroute www.cisco.com for example), but I'm not sure about how to use an inside interface.
Do I have to connect a cable between the inside router port (gi9) and a switch port for example gi0? I've tried it without success.
I'm guessing it's possible make some kind of virtual level 3 inside interface, with ip 192.168.0.1 for example, to use as a gateway for the hosts connected to the switch.
Any ideas? Or documentation links?
Thanks, Lars.
thiland
Level 3
Level 3
Think of it like a layer-3 switch.  How would you do it on a 3750 or 6500?
Create & name the VLAN
vlan 10
 name INSIDE
Assign the L2 switchport to a VLAN
interface G0
 desc Home computer
 switchport access vlan 10
Create a L3 SVI
interface Vlan10
 description Inside Network
 ip address 192.168.0.1 255.255.255.0
 no ip redirects
 no ip proxy-arp
 no shut
thiland
Level 3
Level 3
vlan 10
 name INSIDE
interface G0
 desc Home computer
Create a L3 SVI
interface Vlan10
 no ip redirects
 no ip proxy-arp
 no shut
Bonjour,
je voudrais savoir si quelqu'un pourrait me fournir un fichier de configuration automatique que je pourrais charger en TFTP,
sur mon routeur.
J'ai des difficultés à le configurer j'aimerais avoir la possibilité d'installer l'interface Web pour entrer dans les réglages du routeur.
Modèle 892 FSP.
J'aimerais activer le DHCP pour un usage personnel.
Désolé pour la traduction anglaise
Cordialement
Good morning,
I would like to know if someone could provide me with an automatic configuration file that I could load in TFTP,
on my router.
I am having difficulty configuring it I would like to have the possibility to install the web interface to enter the router settings.
Model 892 FSP.
I would like to enable DHCP for personal use.
Sorry for the English translation
Heartily
Outwill
Je recherche la dernière version du firmware pour cet appareil
Je vous remercie d'avance.
Cordialement
I am looking for the latest firmware version for this device
I thank you in advance.
Heartily
