10-25-2022
01:18 AM
- last edited on
10-27-2022
01:20 PM
by
Tyler Langston
Dear Sir,
Cisco RV042 Small Business router is automatically Restart every 1 minutes. Kindly give the solution to rectify the problem
Maria Joseph. R
11-01-2022 10:12 AM
I only had two of these so it was no big deal to simply replace them with inexpensive ASUS units. I took the two units back to the shop for troubleshooting.
One theory was that this was an attack coming from the WAN side. With that in mind, I fired up the first unit without any WAN or LAN connections. The router *still* rebooted every 1m42s.
This led me to a second theory that someone's figured out how to force a firmware update and has done so with malicious code. If that's so, even a reset won't help. I tried that anyway and would up with a brick.
If it was malicious firmware, then overwriting it with the latest firmware would solve the problem. Of course, the firmware replacement would have to be done in under 1m42s. And that's assuming the malicious firmware hadn't hacked that part of the code. Either way, I now have two bricks.
I'm left thinking that Cisco hasn't responded because the hack is that good: there *is* no solution. Alas!
11-03-2022 10:47 PM
Seems like a bigger Scheme is going on here, no way that all these devices are doing same thing while working fine not changing anything, the only thing I can think of ISP traffic to router or other entity Hacking or some sort of Traffic that is Crashing these routers.
Might be some back door to kill router to force upgrade to new Routers. its unlikely that the problem all over the sudden started with almost same time frame to all devices.
Doomsday Clock ??
11-04-2022 07:50 AM
11-04-2022 10:43 AM
This was happening first now Restarting
11-05-2022 08:48 AM
We have 20 rv42g in production, and last week we had to replace 10, this is crazy. we need a solution.
11-06-2022 11:10 AM
no solution, I have done several options, but none of them solved the problem:
1. I reinstalled the FW
2. I installed an older FW
3. put the RV in boot mode and re-install with TFTP
None of the above solved the problem. this is very frustrating, I am looking for options to replace 20 Rvs.
11-07-2022 10:23 AM
Hi all, any suggestions for a replacement for Rv42 or Rv340?
Regards.
Ecar
11-08-2022 03:41 AM
Hello, we use Tp Link to replace RV042.
2 models depending on the resources you need:
ER605 (small office) and ER7206 (has 1 FO lan/wan input).
VPN IPSec Lan to Lan works ok with Forti F60
We have already replaced 8 RV042/g.
I hope the information will serve you, it will depend on which country you are in and the availability of equipment you have.
12-11-2022 08:41 AM
Tanks.
11-09-2022 01:12 PM
it seems Cisco company died.... they dont answer anything
11-12-2022 07:01 AM
I have 3 RV042 in use. #1 (firm v4.2.3.07 10/8/2015) Started the problem a month ago.....rebooting every 1.5 minutes. #2 & #3 (firm not known at this time) are working fine at this time. Replaced #1 with another RV042 (firm v4.2.3.14 5/28/2020) and is working fine at this time. I'm wondering if Cisco has sent a bullet to disable these units. Kinda like when Adobe sent a bullet to kill Adobe Player in everybody's computers.
11-13-2022 09:38 PM
hi ihave the same problemi have25 rv042 and 8 rv082 whit this problem i need a fix please
11-14-2022 12:44 PM
i spoke too soon....another one bites the dust! Can't communicate with it. Have not tried a factory default reset yet.
11-16-2022 05:35 AM
hi ihave the same problemi have 27 rv042 and 7 whit this problem i need a fix please
11-22-2022 09:23 AM
I've opened a ticket with Cisco for one of my RV042...No action yet. I am switching my Routers to SonicWall TZ270 and TZ370 They should be in sometime this week.
