Cisco RV042 Router automatically Restart every 1 minutes
Maria Joseph R
Dear Sir,
Cisco RV042 Small Business router is automatically Restart every 1 minutes. Kindly give the solution to rectify the problem
Maria Joseph. R
75 Replies 75
raymondnichols
It appears Cisco cares less about all the customers that purchased the RV042 series routers.  What a worthless corporation they have become.  They must not need future business in the United States to treat us in such a way.
Gabriel Badea
Does anyone know the solution to this problem?
As you will find earlier in this thread Cisco acknowledged that this is a major issue that they are looking into.  That was back in October.  I think it's safe to say at this point they will not be doing anything about it.  The only solution is to find another product and replace.
Another bites the Dust, A BRAND NEW Backup unit out of the box worked for about a WEEK or so and getting killed. It might not be restarting every minute but GUI is not accessible, and than BAD GATEWAY, than NAT works for a bit than Completely unaccusable. Powering OFF for few minute's an Powe back on works for a while and than same thing. NOT CONNECTED TO INTERNET WORKS FINE.
Like A Silent kill Pill sent over internet who knows
Mike Cisco User
I reached out to Cisco Tech Support and didn't get a response.  Based on talking with others in the IT world, It looks like Cisco sent a "bullet" to kill the product.  So any units on the Public internet are/were vulnerable to this. I have not seen any posts indicating that units on a Intranet were affected.
Gabriel Badea
What router model do you recommend to replace it?
I have had positive experiences with routers from the ASUS folks. Reasonably priced, reasonably powerful. Not exactly the same build quality as Cisco but still reasonable. The menu/configuration/interface is a zero sum of pluses and minuses.
TP Link - ER605 (small office) and ER7206 (has 1 FO lan/wan input)
Gabriel Badea
Hello, any updates?
Gabriel Badea
I want to replace the RV042 router with another router model.
What do you recommend?
I replaced it with MIKROTIK rb750, for the application I use it worked very
well. The configuration follows a very different concept, but there is a
lot of content on the WEB to clear up doubts.
VENKATREDDY
At last in warranty RV042 devices replaced by cisco.Once spoke with customer care and replace the devices
Good news, how was the process, which team they replaced you with, I still
haven't received an answer.
VENKATREDDY
0008001001364 customer care number
