cisco rv220w quickvpn connection problem
tk lam
First, I setup quickvpn on a firmware 1.0.3.5 the connection is fine
but, after i update the firmware to 1.0.4.17 it keeps give me the error said connection problem, like incorrect password, ip conflict, check network issue...
however, i update the firmware to 1.0.5.8, same issue
how can i solve it
thanks
5 Replies 5
mpyhala
Level 7
Level 7
tk,
Delete the username and password from VPN Users and create a new one. Sometimes the problem is with a corrupt user database.
Can you ping the WAN IP from the internet if that feature is enabled in the firewall?
Is Remote Management enabled and working on port 443 or 60443?
- Marty
I try create new quickvpn user for testing and delete old one
I cannot ping wan ip, but i dont think this is an issue, because in 1.0.3.5 quickvpn is working
remote management is enable and port 60443
tk,
The reason I ask about ping and remote management is to establish that inbound traffic is able to reach the router. If you cannot ping the router or manage it remotely then you likely cannot connect using QuickVPN either.
Go to Firewall-> Attack Checks and enable: Respond to Ping on WAN (Internet)
From the internet, try to ping the WAN IP of the router.
"remote management is enable and port 60443"
That is good and it is required for QuickVPN access. The question is, does it work? Can you reach the router from the internet if you type https://:60443 and log into the web interface?
- Marty
Hi, Marty
I can ping WAN IP:60443 and https:\\WAN IP:60443 and logon to the web interface
but still not working for the quickvpn
Error msg as below
Failed to establish a connection
This could be casue by one of the following
1. Incorrect password
2. No valid IP for the network card
3. Incorrect server address
4. Windows Vista/Windows7 with Windows Firewall disabled, which disabled IPSec service
5. Local IP address conflicts with the subnet of remote VPN Server
mpyhala
Level 7
Level 7
tk,
Please open a case for further troubleshooting.
www.cisco.com/go/sbsc
- Marty
