Cisco RV340 bandwidth usage
VideoR1
I can see a table of packets and bytes send/received.
How can I see how much bandwidth is being used in real-time?
balaji.bandi
You can view in the dashboard of GUI  ( you can refresh on GUI - make sure you hit right the button, there is Refresh and Reset - reset clear all the counters)
Status and Statistics --> system summary
Status and Statistics --> port-traffic
Another option you can setup NMS with SNMP to get the details.
BB
Sujoy Paria
With the help of any Network Monitoring and Management software you can view the traffic flow per port. For example, in Cisco Business Dashboard application, Traffic widget displays a graph of the input and output traffic in bps / kbps (5 minutes interval) flowing through the selected interface.
