01-05-2019 05:16 PM
I upgraded my RV340 router from 1.0.01.16 to 1.0.01.18 and everything seemed to go fine until I logged back into the web gui interface and the page is basically blank with some garbled text. Everything was working fine before I updated the firmware. Is there a way to recover the router? I have reset the router back to factory defaults and the web interface is still the same. Any further ideas on how to correct this issue? Attached is the screen shot of what the web interface looks like after logging in.
01-05-2019 05:28 PM
Attached is the screenshot
01-06-2019 01:40 AM
have you tried any other browser or clear the cache and try.
01-08-2019 04:55 PM
01-07-2019 10:12 AM
Happy New 2019 Year!
Try to type 192.168.1.1 again in address field and hit 'Enter'
Any change?
Cheers,
Mike
01-08-2019 05:00 PM
01-08-2019 11:52 PM
Here is the workaround for your problem.
01-13-2019 03:29 PM
So, I've upgraded my firmware to 1.0.02.16 and I can no longer access the Admin GUI web page. Every browser I've tried says "refuse to connect" with both http and https the default IP address pings and FING says its the router.
How can I get to the admin page?
Thanks.........dP
01-13-2019 10:29 PM
As per your concerns you have tried all the combination to resolve the issue, But it was not fixed,so can you please contact Cisco TAC, they can jump on WebEX and have a look for you it is only solution i can see for you now.
01-14-2019 04:46 AM
Did you reset it to factory defaults and try again?
