Cisco RV340 with Active directory use Authentication
Hari Kumar Raja
Hello ,
i recently purchased Cisco RV340 and my current Firmware Version: 1.0.03.20 , i have configured ssl vpn with local users and able to connect with out any issues, i have an Active Directory and when i am trying to configure with my AD it was not authentication , i tried to configure as showing in cisco blogs but failed , can any one please help me out how can i fix this issue .
using Win2019 Standard server .
regards
Hari
9 Replies 9
balaji.bandi
tell us what steps you followed :
1. you need to setup user accounts with Remote Authentication Service
2. Integrated with AD
3. you need to add your Device in AD as trusted device
follow below guide :
https://thesolving.com/server-room/configure-radius-server-windows-authenticate-cisco-vpn-users/
4. make a Groups so user will be part of VPN
check Logs both the side windows event logs and RV 340 what is the logs shows when the user dialed in ?
BB
Hi Balaji ,
i tried with this but no luck , i have configured radius on my win2019
server and when i am trying with AD users which was in group getting the
error . the authentication was thrown back .
attached log for cisco rv340 . can u please help me to fix this out .
regards
Hari
balaji.bandi
So you are using Radius authentication, intern radius do AD lookup ? is this correct?
in this case you need to see related between radius and AD connection.
your Logs are missing ?
BB
yes ,
i have a AD setup for my users , most of the users will work remotely and
want to integrate with my AD , so we dont need to create local users and
they can use same domain logins to login .
attaching logs again .
regards
Hari
Your Logs still missing . - make sure attached correctly.
let me brief again.
1 user dial in to RV
2 RV use Radius to authenticate users
3. Radius installed in windows box - what radius ? is this windows NPAS ?
4. Do you have relation between Radius and AD in the same server for the users access ?
BB
Hi Balaji ,
any luck for my issue .
regards
Hari
let me brief again.
BB
Hari Kumar Raja
I solved this my self after downgrading my DC from 2019 to 2016 , its worked with out any major changes in RV .
Thank you Balaji for your assistance .
regards
Hari
balaji.bandi
thanks for feed back and glad all working as expected at end.
BB
