Firmware 1.0.3.51 for Cisco RV130/RV130W download links
cbjwthwm
I received release notification for this firmware, but all of the download links here are dead:
https://www.cisco.com/c/en/us/support/routers/rv130-vpn-router/model.html#~tab-downloads
Release notes aren't yet available, but I assume they'll be released in the next few days.
Previous releases seem to have fixed the majority of stability issues with the router's hardware acceleration enabled (aka configured with QoS disabled) but I did have issues at one site a few days ago and re-enabling QoS seemed to resolve the routing issues immediately.
That site's WAN is < 100Mb service anyway, so having to enable QoS to stabilize operation luckily doesn't limit performance.  My tests on previous firmware releases showed WAN-LAN throughput peaking around 130Mb when QoS was enabled.
cbjwthwm
The download links just started working and the release notes are now available too. Impressively fast, thank you Cisco :)
cbjwthwm
boco1998
Hi.
I'm looking for latest upgrade for my router:
https://www.cisco.com/c/en/us/support/routers/small-business-rv-series-routers/series.html#~tab-downloads
Are download buttons dead or I'm missing something?
If there is no way to download firmware, what is alternative?
I'm trying to resolve this problem:
thanks, Bojan.
boco1998
After I restarted router for the couple of times, problem with "Device firmware file has been corrupted" has been solved.
So, I don't need new firmware file. But the truth is that the download button still doesn't work.
