FTP Failing with Multi WAN Setting
macfan007
Here is setup
RV340 connected to 2 ISPs
WAN1 - PPOE
WAN2 - PPOE
Multi WAN Setting
I can see that traffic is being routed through both WAN connections, but we're unable to establish a stable FTP connection to any server. It might require using a single WAN connection.
   - I assume that because FTP use a different link  for data and control connection that client-and-server get confused when multi-wan is used , so the solution is then to either disable it or 'use only plain FTP' as mentioned earlier (if possible)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
8 Replies 8
Mark Elsen
  - Make sure to use  the latest firmware on the device ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
macfan007
@Mark Elsen I am on latest fw.
Problem is something else . we are able to FTP to server and then it disconnect on next command . Probably with Multi-WAN setting it change the WAN IP on subsequent action/command.
  - Ok . also check the logs on the RV340 when those things happen ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
macfan007
Thanks @Mark Elsen for replying .
Nothing on RV300 Logs during error and FTP works fine when we set precedence 1 and 2 for WAN1 & WAN2 . The only time it doesn't work when we set precedence 1 and 1 with 50-50 ratio.
Here is logs from client side.
GnuTLS error -110: The TLS connection was non-properly terminated.
Server did not properly shut down TLS connection
The data connection could not be established: ECONNABORTED - Connection aborted
 - For the particular ftp client being used make sure it's version is up to date : there is an interesting discussion about this error in
   https://forum.filezilla-project.org/viewtopic.php?t=34931
   Also from https://community.brightlysoftware.com/s/article/Resolve-Confirm-Error-GnuTLS-error-110-The-TLS-connection-was-non-properly-terminated-error-using-the-Confirm-OnDemand-ftp-site
  I found :
           Resolution
       Beauty and terror
      Just keep going
       No feeling is final
macfan007
Thanks @Mark Elsen for clarification. It seems nothing to do with RV340. It's Server and client issue. The best way to disable one WAN during FTP works rather use plain without impacting security.
What you suggest ?
 M.
       Beauty and terror
      Just keep going
       No feeling is final
SamirD
Level 5
Level 5
The best thing to do is bind traffic for FTP to one wan or the other.  I had the same problem with multi-wan breaking https SSL connections until I did this.
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
