03-15-2012 09:10 AM
how to connect gateway to gateway RV110W and rv042 ??
03-15-2012 01:42 PM
Hi Mate,
Thank you for posting. The RV110W does not support Gateway to Gateway VPN tunnels. Check out the RV120W if you need that functionality.
10-03-2012 12:02 AM
I down load a FW update so GW to GW VPN is supported put does not work fine i have a connection but I could not Ping the remote site
10-18-2012 05:20 PM
Could you ping the LAN IP of the remote router over the tunnel?
10-18-2012 05:55 PM
no,
actually the tunnel is never established
I have a post where I show the configuration I am using (in both side the RV042 and the RV110W)
10-22-2012 12:05 AM
I try to ping both sides and i get that:
any one can explain that???
10-22-2012 09:01 AM
It could be cuased by the computer in the LAN of RV042 rejecting the ping.
10-23-2012 12:34 AM
I try to ping a switch not a PC and I also try to ping LAN interface of VPN router still same problem
10-18-2012 05:07 PM
I have download the firmware 1.2.0.9 for the RV110W
and it does support GW to GW VPN
I also have a RV042 in the other side, but I also was unable to connect them
10-22-2012 06:56 AM
Hi Roberto Sagastume
In order to configure your router RV042 here i posted a link with the Gateway-to-Gateway configuration. And about the RV110w configuration, I´m working on it .
Best regards and have a nice day
Johnnatan Rodriguez Miranda
If this answer was satisfactory for you, please mark the question as Answered and rate useful answers.
Thank you.
10-22-2012 02:33 PM
Check your Rv110w configuration, use this guide in order to setup up your router, you can find the settings in ¨Configuring Basic VPN Settings (Site-to-Site VPN)¨.
http://www.cisco.com/en/US/docs/routers/csbr/rv110w/administration/guide/rv110w_admin.pdf
Thank you.
