gateway to gateway RV110W and rv042
mat89mksMateusz
how to connect gateway to gateway RV110W and rv042 ??
10 Replies 10
mpyhala
Level 7
Level 7
Hi Mate,
Thank you for posting. The RV110W does not support Gateway to Gateway VPN tunnels. Check out the RV120W if you need that functionality.
I down load a FW update so GW to GW VPN is supported put does not work fine i have a connection but I could not Ping the remote site
Could you ping the LAN IP of the remote router over the tunnel?
no,
actually the tunnel is never established
I have a post where I show the configuration I am using (in both side the RV042 and the RV110W)
https://supportforums.cisco.com/message/3763284#3763284
I try to ping both sides and i get that:
  1. I ping from RV110 side to RV042 side I get Req time out
  2. I ping from RV042 side to RV110 side I get a reply
any one can explain that???
It could be cuased by the computer in the LAN of RV042 rejecting the ping.
I try to ping a switch not a PC and I also try to ping LAN interface of VPN router still same problem
I have download the firmware 1.2.0.9 for the RV110W
and it does support GW to GW VPN
I also have a RV042 in the other side, but I also was unable to connect them
Hi Roberto Sagastume
In order to configure your router  RV042 here i posted a link with the Gateway-to-Gateway  configuration.  And about  the RV110w configuration, I´m working on it .
http://sbkb.cisco.com/CiscoSB/ukp.aspx?vw=1&docid=8c6825b4d43d4886be44afde263a41aa_Configuration_of_Gateway_to_Gateway_VPN_on_RV0XX_Series_Rout.xml&pid=4&fcid=&fpid=&slnid=7
Best regards and have a nice day
Johnnatan Rodriguez Miranda
If this answer was satisfactory for you, please mark the question as Answered and rate useful answers.
Thank you.
“Please rate useful posts so other users can benefit from it” Greetings, Johnnatan Rodriguez Miranda. Cisco Network Support Engineer.
Check your Rv110w configuration, use this guide in order to setup up your router, you can find the settings in ¨Configuring Basic VPN Settings (Site-to-Site VPN)¨.
http://www.cisco.com/en/US/docs/routers/csbr/rv110w/administration/guide/rv110w_admin.pdf
Thank you.
