I can not connect to internet using my cisco router
Eyobaa
Dear All
Today i have installed a new 1921 Cisco Router, i wanted to connect my isp modem to one of the gigabit port at the router, and then my pc to the other gigabit port.
i have configured my pc ip statically to be in the same range of the gigabit port 0/1
the isp modem port is in the same range of the gigabit port 0/0
the isp modem can not do dhcp service
the network is like this
PC (192.168.1.5)  ==> router port 0/1 (192.168.1.1)
isp modem ( ip address:-10.141.54.104, subnet mask:-255.255.255.240 getaway:- 10.141.48.1 )==> router port 0/0 (i dont know)
Using 1541 out of 262136 bytes
! Last configuration change at 07:18:02 UTC Wed Jul 18 2018
version 15.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 25
ip dhcp excluded-address 192.168.1.1 255.255.255.0
ip dhcp pool Eagle-pool
 import all
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.1
 dns-server 213.55.96.166
 domain-name Eagle.lan
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO1921/K9 sn FGL211522EF
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 10.141.54.105 255.255.240.0
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip nat inside
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 10.141.48.1
ip route 0.0.0.0 0.0.0.0 10.141.54.104
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
control-plane
end
Please Help
Thanks!
That doesn't much much sense that 10.141.54.104 works and .105 won't. It's the same subnet.
Anyhow, if the ISP gave you the .105, then I'd talk to them about it.
Also I noticed a mistake in your configuration. The access list for NAT is incorrect, it should be 100 and not 1:
ip nat inside source list 100 interface GigabitEthernet0/0 overload
That and remove the "ip route 0.0.0.0 0.0.0.0 10.141.54.104" if 10.141.54.1 is the proper gateway.
Hope this helps.
13 Replies 13
chrihussey
If you connect your PC directly to the ISP modem and give it the 10.141.54.105 255.255.240.0 IP with the gateway being 10.141.48.1 or 10.141.54.104, does it have Internet access? (Make sure you also configure the DNS server).
sorry for to late to respond, no sir it don't work but work like this like picture.
Hope this helps.
 no ip address
 shutdown
 ip address 10.141.54.104 255.255.240.0
 ip nat outside
 duplex auto
 speed auto
 ip nat inside
 duplex auto
 speed auto
no ip http server
control-plane
Thanks sir everything is worked but,
1.when power goes and come back, the "no shutdown" command disabled it self every time.
2. and then first i can ping from my pc to getaway ip and google.com now i cant.
first everything's worked then when power goes and come nothings working the configuration is stile there. WHY help please
THANkS.
Glad to hear things are working.
After you made the changes and got it working did you do a "wr mem"?
Can you post the output of "sh ver"?
After the power outage, could the router ping 10.141.54.1, was the interface up?
yes i did save the config "copy run start" or "wr mem" but when the power goes and come the interface wont start itsel unti i do "no shut" command to each interface.
here "sh ver"
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.4(3)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 05-Jun-15 12:31 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Router uptime is 31 minutes
System image file is "usbflash0:c1900-universalk9-mz.SPA.154-3.M3.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1921/K9 (revision 1.0) with 446464K/77824K bytes of memory.
Processor board ID FGL211522EF
2 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
245744K bytes of USB Flash usbflash0 (Read/Write)
Technology Package License Information for Module:'c1900'
Technology    Technology-package                  Technology-package
              Current              Type           Next reboot
ipbase        ipbasek9             Permanent      ipbasek9
security      None                 None           None
data          None                 None           None
NtwkEss       None                 None           None
Configuration register is 0x2142
Change the configuration register to 0x2102, then do a "wr mem", then try reloading or power cycling the router and then see if the interfaces come back without having to no shut them.
How can i change that, i don't no the commands, give me some idea
Thanks Sir
conf t
config-register 0x2102
end
wr mem
Very very Thanks sir for your time and sharing ideas.
Everything is working now on my pc.
but i want to connected to switch, switch model- "sf300-48pp 48 port managed switch"
the switch needs configuration?
Thanks sir.
So you want to connect the router to the switch and your PC to the switch. Correct?
I'm not familiar with the SF300s, but if you are only using a single subnet (192.168.1.0/24), then out of the box the SF300 may work for you. I don't think you'll need a crossover cable from the switch to the router as the router has a Gig interface. Suggest just connecting everything and see if it works.
i did that, but it don't work
but i plug my pc to switch and i give the pc ip 192.168.1.3 255.255.255.0 getaway 192.168.1.1 and dns server 213.55.96.166 it works, i think the switch needs dns ip and getaway ip
So if you give your PC a static IP and it works, but not with DHCP, you probably need to enable "spanning-tree portfast" on the switch ports. As stated earlier, I'm not familiar with that particular switch but the documentation should provide the answer.
