i Unable to block web sites using keyword in RV016
Global Networks
Dear Firends,
In RV016 Router i unable to block websites using Keywords in content filtering page. I added domain name as facebook.com but still i can access the facebook from my LAN computers. we not purchased Cisco Protect Link web licence so we using content filter.
Senthil
Network Engineer
Global Networks
7 Replies 7
jeffrrod
Level 4
Level 4
Dear Customer,
Thank you for reaching the Small Business Support Community.
The content filter rules will be automatically disabled if the Cisco ProtectLink service is activated on the router so please double check it is not.  Besides I suggest you to run the latest firmware release v.4.2.2.08;
http://software.cisco.com/download/release.html?mdfid=282413305&flowid=783&softwareid=282465789&release=4.2.2.08&relind=AVAILABLE&rellifecycle=&reltype=latest
Below, and just to double check on the "Content Filtering" configuration and usability, is an interesting document about it;
https://supportforums.cisco.com/docs/DOC-36653
Please double check on this and let me know if anything comes up and/or if there is any further assistance I may help you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
aunrein
Here is an article that you might want to use to double check your settings.
Content Filter Configuration on RV016, RV042, RV042G and RV082 VPN Routers
I hope this helps.
Alex
Thank you Jefrey and Alexander.
This works on next day. All the changes which i made is updating in running config on next day only. so it works for me.
If you guys help me out to configure VPN using Quick VPN it will be helpful.
I can able to connect through Quick VPN  but can able to access the LAN devices.
Local configuration:
_______________
I Have one static IP 117.218.xxx.xxx
ISP VDSL modem 192.168.1.1
Local LAN subnet 10.10.10.0/24
Remote Config:
____________
Remote LAN:192.168.1.0/24
No Static IP
ISP provided DSL modem with 192.168.1.0/24 subnet
I have created the VPN group ,users
i uploaded the cerificate to Quick VPN also. Its connected but unable to Access those 10.10.10.0/24 subnet devices.
Thanks in advance
Here is an article that can help with QuickVPN.
Manage VPN Users and Configure Quick VPN on RV016, RV042, RV042G and RV082 VPN Routers
Let me know if this helps.
Alex
Ryan Jay Gil
hi, i still have the same problem.
Thiing is, i blocked facebook using content filtering and using Block Forbidden Domains. but when i try accessing facebook trough https://www.facebook.com the router allowed that request. But when i disable my https request in the router all my https site tools are unreacheable. Is there anyway i can blocked https of social media without blocking any https request of other websites like my webtools?
Thanks CISCO
If you want to block HTTPS websites, use opendns.
None of the Cisco  SB routers will block HTTPS.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
SamirD
Level 5
Level 5
Another method you can use to block certain sites is an access rule for the IP address.  Sure, this will change periodicly, but you can still block it this way.
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
