Ipsec tunnel and Vlan
duvelke87
i'm using an rv220W and i whant to know if is it possible to assign vpn traffic to a vlan when i setup an ipsec tunnel?
or is there mybe another solution?
example:
Im using different vlans on my rv220W.
Vlan 10: engineers (ex: 192.168.1.0/27) no intervlan routing
Vlan20: sales (ex: 10.0.123.0/24) no intervlan routing
This is what i need:
     - An engineer is on the road and when he makes a ipsec vpn connection => assignd to the vlan "engineers" so he can access the server/pc's in that vlan.
and when someone from the sales group starts a vpn connection he needs to be in the vlan "sales" so he can access his pc/data,...
Dimitri
15 Replies 15
weslsmit
Hello Dimitri,
What is the VPN client that you are using here? Did you setup a Quick VPN connection or did you setup an IKE/IPSec policy?
Wesley S
Hi Wesley,
the RV220W is the gateway and i will use my laptop with the application "cisco quick vpn" to connect to the rv220W
so i need to setup an ike/ipsec policy i guess?
Thanks!
Dimitri
Dimitri B,
No the QuickVPN feature allows you to only configure the remote management settings and create a QVPN user. These settings automatically build the rest of the configuration for that VPN.
Cisco Small Business Support Center
Randy Manthey
CCNA, CCNA - Security
but can a vpn user then communicate with a device in a specific vlan? our is that not possible?
not in time, but...
solution:
username PC1 password 0 !encrypted!
username PC2 password 0 !encrypted!
vpdn-group DEFAULT
! Default L2TP VPDN group
accept-dialin
  protocol l2tp
  virtual-template 5
vpdn-group PC1
accept-dialin
  protocol l2tp
  virtual-template 1
terminate-from hostname PC1.DOMAIN.COM
local name PC1
vpdn-group PC2
accept-dialin
  protocol l2tp
  virtual-template 2
terminate-from hostname PC2.DOMAIN.COM
local name PC2
interface Virtual-Template1
ip unnumbered Vlan1
interface Virtual-Template2
ip unnumbered Vlan2
interface Virtual-Template5
ip unnumbered Vlan5
Dimitri, I have exactly the same requirement. Did you ever find a solution?
Andrey, the RV220W doesn't support running scripts like enterprise routers/switches as far as I know.
pptp should permit the intervlan communication. you won't be able to 'directly connect' to that one specific subnet but you will be able to communicate across a vlan as you wish... and the router supports inter-vlan acl so you may limit traffic as you wish.
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Thanks Tom. Is IPSec not an option at all on the RV220W for this particular requirement?
Of course I haven't verified it for myself but reading this sort of thing on Wikipedia doesn't inspire confidence: "PPTP is (as of Oct 2012) considered cryptographically broken and its use is no longer recommended by Microsoft."
Historically your statement is true, the IPsec wouldn't be an option on this unit. You may try to make a LAN to LAN access rule in the attempt to make it work, since the LAN to LAN rules are a new addition, it may work (I haven't tested it for this purpose yet).
-Tom
It's the MS PPTP implementation that's broken, not PPTP itself.
See
http://www.schneier.com/pptp-faq.html
Richard Iemand:
Richard, really? Give me a link please!
And what  type encryption i can use for security?
(Sorry my English)
Another option is the SSL vpn, this can be full tunnel or split tunnel. The router supports 5 SSL connections.
-Tom
Hi Thomas,
i dont think that the ssl vpn is a solution.
for example you cant add 1 ssl connection in vlan 10 and another in vlan 20.
greetz
Dimi
Hi Richard,
did not found a solution... do you?
