routing all traffic to a vpn site to site with SRP527W
vincent.munier
I'd like to create a site-to-site vpn between an SRP527 and an other vpn gateway. The problem is i don't see how to route all traffic from the local network (network defined by the lan ip interface of the SRP527) to the other vpn gateway? It seems to be only possible to define the destination network (accessible via the vpn) with ip/mask (but only for "small" network: for exemple i tried with 10.2.0.0 mask 255.255.0.0 and it's ok but i tried with 10.0.0.0 mask 255.0.0.0 -> it's not working. I obtain the message "invalid ip")
Thanks for your help!
Sincerly
Vincent
Andrew Hickman
Hi Vincent,
Unfortunately this feature is not supported by the SRP500.
Andy
