01-06-2013 05:36 AM
I like to use „URL Blocking“ with keywords in the firewall properties. When I activate this feauture, I get errors from the router certificate when I browsing to any site in the Internet.
Is there a way to manage this problem without using a public certificate?
RV180W-Firmware-1.0.1.9
Solved! Go to Solution.
01-11-2013 06:02 AM
Hi Stefan,
You can´t block https sites in your router, if you want to do that, you could use a third party software such Protect link or Opendns, however if you already rebooted your router and configured manually twice and it still not working you, can you please reach out to our Small Business Support Center and open a Service Request to address this issue? One of our Engineers may be able to work with you and diagnose the root cause. You can find the appropriate contact information for SBSC in the below link.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html , you can also confirm if this is a bug. I encourage you to share the answer with the community, it would benefit us. I hope you find this answer useful,
*Please mark the question as Answered or rate it so other users can benefit from it"
Greetings,
Johnnatan Rodriguez Miranda.
Cisco network support engineer.
01-09-2013 08:58 AM
Good morning
Thanks for using our forum
Hi Stefan my name is Johnnatan and I am part of the Small business Support community. In order to resolve your problem Stefan, could you provide us what certificate error do you receive? Also, can you provide us some screenshots about your firewall configuration? Also, I apologize for the issues you are having.
Greetings,
01-09-2013 11:32 PM
Dear Johnnatan,
...the name from the website do not accord with the name on the certificate (router certificate?). The problem starts, when I browsing to a blocked keyword. The firewall is in basic configuration. I just activate "url blocking" for testing. The certificate message will then also appears on other device in the network when they browsing to unblocked sites....I have no additional Certificates installed on the router.
Best Regards
Stefan
01-10-2013 05:52 AM
Hi Stefan, that was my next question, if have you installed an additional certificate, you could do factory reset to your device (always make a backup of your data) and manually set your configuration (if you can)
Greetings,
01-10-2013 06:04 AM
Hi Johnnatan,
firmware update and factory reset allready done....It`s ok for the moment. I took another router where I know it works and I can use this router for another customer. no problem!
Stefan
01-10-2013 06:57 AM
Hi Stefan, remember you can post any any doubt or questions you have, and we´ll help you
Greetings,
01-10-2013 10:42 AM
Hi Johnnatan,
could you tell me if it`s really necessary to generate and install a new self signed certificate, authorized from a public or an own CA to use this feauture? Is it not possible to block a simple static keyword or a url without this action or is it a bug?
I saw on a RV220 you make difference between http and https....but it works....?
The original router certificate is not useable because it is generated with the mac address. Every new browser hate this!
Stefan
01-11-2013 06:02 AM
Hi Stefan,
Greetings,
01-11-2013 02:57 PM
Hi Johnnatan,
so static URL blocking or keyword blocking is not really working on this router! This was one of the reason for evaluating this product because it was on the feauture list....
Thanks for informations
Stefan
