RV016 and WAP321 with a guest network
John McArthur
I have two Cisco WAP321 AP's and a Cisco RV016 Router.
I use the RV016 as the DHCP server for the network.
I  would like to use the guest SSID mapped to a VLAN to issolate it from the rest of the network.
How do I setup the  RV016 to route traffic from both the guest VLAN and the internal VLAN to  the internet while still using it as a DHCP server.
Thanks for any assistance.
John McArthur
Hi, this is basically an unsupported configuration. The RV016 supports only port based VLAN and only 1 DHCP scope. If you want a guest VLAN inconjunction with the router something like a layer 3 switch would need to be implemented between the router and AP to accomadate this configuration.
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
sirblabla
I also would like to hear the answer :) (bump!)
