RV016 downgrade firmware?
abelbrazal
Hi all,
Is it possible to downgrade my firmware from  v4.2.2.08 (Apr 26 2013 19:12:26) to v4.1.0.02-tm (Sep 16 2011 18:40:48)? if yes, what are the possible things to happen if i downgrade (i.e. returning to default config, etc)? and what does the "tm" stands for at the end of v4.1.0.02-tm?
thanks.
Kremena Ivanova
You can downgrade the firmware of RV016 to 4.1.0.02. The Release notes does not say that it will make factory default of the configuration, but I would advise to make factory default after the downgrade and to reconfigure manually the device. The new firmare versions contain big fix and enhancements. Once you downgrade you just lose the fixes. You can see the Release for more information:
http://www.cisco.com/en/US/products/ps9923/prod_release_notes_list.html
Kremena
Kremena Ivanova
Kremena
Thank you. i'll do it later.
