10-21-2011 07:50 AM
On RV016 router WAN port 1 is showing Half duplex wen i check it in Port setup but when i check it on Port status its showing me as Half duplex, how can we
force it to make it full duplex.
10-21-2011 11:04 AM
I took a look at my RV082 and my wan port is also half duplex but I have auto negotiation enabled so I am assuming that my wan router can only support half duplex. Are you sure the device you are plugging into your wan port can support full duplex?
-Adam
10-24-2011 06:17 AM
Hi Adam
Thanks for your reply but i was able to figure it out and make it Full duplex.
I just disable the Auto-negotiate and then forced it to be Full duplex mode and then it was showing as Full duplex.
Pragnesh
