RV016 with two wireless APs
florianmoser
Hi there,
a few weeks ago we started with a RV016 to balance our traffic to the outside.
Now we like to let some wireless clients to access the network.
There should be a wireless network for guests and a "normal" one for co-workers. Both with different subnets.
Is there a best pratice to implement somethine like that?
Which access points are easy to setup / maintain and give us a proper solution?
Any help is appreciated.
Kind regards.
Florian
jeffrrod
Level 4
Level 4
Dear Florian,
Thank you for reaching Small Business Support Community.
I would personally suggest you the Cisco WAP321 access point, among the things I like the most are;
-  WLAN 802.11n
-  Wireless isolation between clients
-  8 Multiple SSIDs
-  Up to 32 connective users, 20 active users
-  SSID to VLAN mapping
-  An affordable price
It is perfect for connecting up to 20 employees on a single WAP321. With Single Point Setup, the wireless LAN can scale up to a total of eight WAP321 devices to provide broader coverage and to support additional users as business needs change. For more details about it below is a link with its datasheet;
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps12237/ps12249/c78-697406_data_sheet.html
Please let me know if there is anything else I may assist you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
I have two Cisco WAP321 AP's and a Cisco RV016 Router.
I use the RV016 as the DHCP server for the network.
I would like to use the guest SSID mapped to a VLAN.  How do I setup the RV016 to route traffic from both the guest VLAN and the internal VLAN to the internet while still using it as a DHCP server.
John McArthur
I think this would be possible using the vlan by port feature.  Set up a vlan2 for the guest access port and connect it.  Set up vlan3 for one of the other ports and connect the rest of the network there.  I think both would be able to route to the Internet without seeing each other.
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
SamirD
Level 5
Level 5
One easy way to do this is to simply get two standard access points and connect them to two different vlans.
