RV042 Class B subnet
slaterkeith
How can I enable a class B subnet on a RV042. It only gives me an option for 255.255.255.0, not 255.255.0.0.
daviddun
Level 3
Level 3
Keith,
The RV042 is a SMB product that only supports Class C routing.  I would recommend that you look at a ASA product or higher if you need to have Class B routing.
Attached is the link to the  comparison guide for your reading pleasure
http://www.cisco.com/en/US/products/hw/routers/products_category_buyers_guide.html
From what I have read, I should be able to change it to a class B if I telnet in and manually make the change. This leads me to my other question which is unanswered:
https://supportforums.cisco.com/thread/2090284?tstart=0
RV042 allows you to specify multiple subnets on the Setup>Network page of the Web Admin interface, but it does not support a true class B subnet.
