RV042 Failover
guilhermek
Hello!
Need some help with this situation.
Have one RV042 configured like ahead:
2 WAN links in Smart Link backup mode (WAN1 Primary)
WAN1 - Cable modem
WAN2 - DSL router
Network service Detection
Remote host: 8.8.8.8
Dns Lookup host: www.google.com
When i poweroff Cable Modem, NSD Fail occurs and failover works correctly.
But, when i remove only the data cable of the Cable Modem, simulanting a problem inside Cable Modem Company, failover not occurs.
Log show NSD FAIL WAN but nothing works to outside.
I've tried load balance mode in the same config above but this doesn't works too.
paolo bevilacqua
Wrong forum, post in "small business - routers". You can move your post using the actions panel on the right.
Te-Kai Liu
Level 7
Level 7
For failover to occur, you need to specify:
When fail, log AND remove the connection. See attached screenshot.
Well, i did it!
Only when i poweroff cable modem or dsl modem failover occurs naturally.
j.spiess
Hello!
Similar problem here , but with a rv320 with the latest firmware !
Best regards
Philipp
