03-07-2013 12:28 PM
I am trying to make this router prefer Wan1 for outbound while listening to both WAN ports for Inbound.
I set it to Load Balance mode and added in a rule for Protocol binding:
All Traffic( TCP & UDP/1-65535)>192.168.1.1~192.168.1.254(0.0.0.0~0.0.0.0)WAN1 ENABLED
This says bind all Outbound traffic to anybody to WAN1
My Wan 2 connection is over satellite so it is easy to tell if a ping is going over Wan2 because the latency is >600mS
If I start a continuous ping to outside site - eg Yahoo.com then if I Fail WAN1 I see the ping latency Jump from 30mS to 700mS as it starts to use Wan2.
If I restore the Connection to Wan 1 then the pings stay on WAN2 - seemingly forever.
If I stop pinging for 30 mins then a restart of pinging does use Wan1 - so it fails back eventually
If I restore Wan1 and then remove Wan2, it fails back right away
My problem is with our VOIP which uses a connection keepalive so there is no real downtime for the router to release the path to WAN2 should it fail over
Any ideas how I can force the router to fail back to Wan1 without removing Wan2?
Bill
03-07-2013 12:42 PM
Hi Roland, I believe you can use network service detection. This will allow the router to detect network connectivity by pinging specified devices.
Give this a try and see if it helps. You can find the configuration System Management -> Dual WAN
-Tom
Please mark answered for helpful posts
03-08-2013 05:07 AM
I am using network service detection and see the same problem either way:
so if I unplug Wan 1 then my traffic goes to WAN2 and stays there after Wan 1 is plugged back in
Using Netork Service detection, if my Wan 1 remote host becomes unpingable ( because I unplugged that) then my traffic goes to WAN2 and stays there after my Remote host becomes pingable again
I can see from the log that there is an NSD FAIL WAN(1) followed by my test pings switching to WAN2 ( called eth2)
when the remote host is restored I see NSD SUCCESS WAN(1) but the pings continue on WAN2
04-05-2013 09:49 PM
I'm having this exact problem as well with voip especially. Someone from Cisco want to chime in here?
I've tried rv082, rv042 and latest firmware on both. Still no dice. My steps to replicate are exactly as Roland mentioned above.
