02-21-2013 08:48 AM
Is there any converter required? or a toggle switch to select 110/220? or can one just plug in 110 power and switch to 220 without changes?
Solved! Go to Solution.
02-21-2013 10:06 AM
Hi Amiller, there is no toggle switch. It supports both. So long as you have a correct power adapter/source should not be any problems.
Here's the datasheet for more power info
http://www.cisco.com/en/US/prod/collateral/routers/ps9923/ps9926/data_sheet_c78-501227.pdf
-Tom
Please mark answered for helpful posts
02-21-2013 10:06 AM
-Tom
07-12-2013 08:33 AM
Forgot to say thanks for the quick reply back in Feb. We plugged in one of the units at our remote location which only serves 208v/220v and the device powered up just fine and has been working good since.
-Adam
