RV120W Admin Question - Large-Scale Scale Deployment
s-daly
Hello:
I've been demoing the RV120W for consideration of deploying these for a 'large-scale SOHO deployment', possibly hundreds of sites. While I'm not a big fan of the fact that there is no CLI, only a web interface, the RV120W does appear to do all the functionality that I need it to do on a basic level. However, since there is no CLI, is there a way to mange these for a large-scale deployment? For example, is there a way to backup configurations over the network, or a way to perform configuration changes to all the routers at once, on an automated level, such as CiscoWorks, or some other tool? I have not found or read about anything that would be suitable for this router. . .
Tom Watts
There are not any tools for a mass deployment. About as far as it goes is make a 'master config' load to each router then tweak the unique attributes. I think in all matters, it will be a cumbersome process.
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Tom Watts
-Tom
Thanks for the reply. I figured as much, but wanted to make sure.
