10-31-2011 09:57 AM
When I try to export an SSL Certificate for a Client I get a htps.CSR file instead of the .PEM file. So, I can't update the client computer with the correct certificate.
Firmware:
1.0.2.6 |
Help?
11-02-2011 12:31 AM
Really? Nothing?
11-02-2011 09:43 AM
Hello Sir, My name is Eric Moyers. I also responded to your other thread.
I am pulling one of these out of our storage room and looking at the procedure. Will update you when I have something.
Eric Moyers
Cisco Network Support Engineer
SBSC WIreless and Surveillance SME
CCNA, CCNA-Wireless
1-866-606-1866
01-27-2012 06:20 AM
Enable remote access on port 443 or 60443, open http://router.domain.com:60443 and save page ssl certificate from browser to file XXXXXXX.cer. Rename the file to XXXXXXX.pem and move it into QuickVPN program folder.
