RV130W port forwarding works only on VLAN 1 (default)
aurelianchircea
After 2 days of testing and switching firmware including the latest 2: 1.0.3.52 & 1.0.3.54, i cannot get port forwarding to work on an additional VLAN like my VLAN 10 (a /26 subnet).
Port forwarding only works if the internal destination is on VLAN 1.
Anyone else encountered this?
Thank you
17 Replies 17
balaji.bandi
Not sure if understand your requirement, port-forward should work any VLAN inside, please provide more screenshot to understand
here is configuration guide for reference :
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb4994-port-forwarding-on-the-rv130-and-rv130w.html
BB
i've added the screenshot.
So port forwarding to VLAN 10 (10.10.10.128/26) does not work
Port forwarding to VLAN 1 (default) 10.10.10.0/26 works
For clarification, i'm talking about accessing intranet host from internet.
Sure i can undertand out side to inside
can you post VLAN information screen shot also
BB
Hi Balaji,
Added screenshot
also before you ask, inter-vlan routing is enabled.
Thank you.
high level your config seems to be ok. last but not the least.
Couple of test to confirm :
1. Internally from VLAN 1 IP to VLAN 10 IP you were port-fording working ? YES / NO
2. The One Port-forward from Internet to LAN(VLAN 10), can you post output of  ipconfig/all (if windows ?) also netstat -na
BB
At Question 1: i did not do this. I am forwarding :
 WAN to VLAN10 fails
WAN to VLAN 1 works
At question2:
PS C:\Users> ipconfig
Windows IP Configuration
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Site-local IPv6 Address . . . . . : fec0::d82c:683a:f4e9:f8d1%1
Link-local IPv6 Address . . . . . : fe80::d82c:683a:f4e9:f8d1%2
IPv4 Address. . . . . . . . . . . : 10.10.10.140
Subnet Mask . . . . . . . . . . . : 255.255.255.192
Default Gateway . . . . . . . . . : fe80::d6ad:71ff:fe5c:3f3f%2
10.10.10.129
Tunnel adapter isatap.{72BB650E-67FA-4B3C-B78B-AB13201CAF36}:
Media State . . . . . . . . . . . : Media disconnected
______________________________________________________________________________________________
Site-local IPv6 Address . . . . . : fec0::5c2b:6e85:6aea:29f9%1
Link-local IPv6 Address . . . . . : fe80::5c2b:6e85:6aea:29f9%13
IPv4 Address. . . . . . . . . . . : 10.10.10.133
Default Gateway . . . . . . . . . : fe80::d6ad:71ff:fe5c:3f3f%13
10.10.10.129
Site-local IPv6 Address . . . . . : fec0::d0af:204a:7330:7992%1
Link-local IPv6 Address . . . . . : fe80::d0af:204a:7330:7992%10
IPv4 Address. . . . . . . . . . . : 10.10.10.2
Default Gateway . . . . . . . . . : 10.10.10.1
idk why my last reply is not showing up.... posting again
- i only tested like this:
--- WAN to VLAN 10, this fails
---WAN to VLAN 1, this works
---i've attatched a txt file
ok i would like to test below one and confirm server side ok as per the config i do not see any issue here.
Try from 10.10.10.0/26 IP range any IP to try to connect what ever port you like to forward ( as per message you like to do 3389)
10.10.10.133 3389 and confirm  is this works ?
BB
everything works between the internal VLANs
you can see in the netstat from 10.10.10.2:
TCP 10.10.10.2:57583 10.10.10.140:3389
vlan1 host RDP on 3389 to VLAN 10 host.
this works, so i dont need internal forwarding because internal routing between vlans does this for all ports automatically
My problem is reaching a host from the outside (internet/WAN) as source
Since i take as confirmation from VLAN1 to VLAN 10 RDP working.
Try reboot the device after configuring port-forward , save  and reboot and let  us know if that works.
BB
sadly that does not make any difference, i've rebooted dozens of times, factory reset 3 times ....
it only forwards to hosts on VLAN 1 and no external access to hosts on other vlans.
Just to confirm make sure NAT working, try one to one NAT and test ?
If you have rights on the PC/ Server - install wireshark and check are you able to get any request coming in ?
Can you also post your outbound NAT rule screenshot
EDIT : not sure this could have issue here :
the one working config of as below :
The one not working :  ( Can you disable IPv6 here) and test other i was thinking
10.10.10.129
BB
i dont know what outbound NAT config is.
The only NAT options i see in the management interface of the router is the one-to--one NAT, where you need a static public IP.
I have a dynamic public IP
Try the one option i have suggested for I
1 Pv6 disable, - is that works ?
2. from VLAN are you able to access Internet outgoing ?
3. can you post Access Rules screenshot ?
BB
