RV180 IPSEC from Android
Carada001
I am getting this problem when trying to connect to ipsec vpn
Thu May 08 08:10:06 2014 (GMT +0100): [routerBB9298] [IKE] INFO:  Received attribute type "ISAKMP_CFG_REPLY" from 46.135.70.24[32684]
Thu May 08 08:10:06 2014 (GMT +0100): [routerBB9298] [IKE] INFO:  Login succeeded for user  "admin"
Thu May 08 08:10:06 2014 (GMT +0100): [routerBB9298] [IKE] INFO:  XAuthUser admin Logged In from IP Address 46.135.70.24
Thu May 08 08:10:06 2014 (GMT +0100): [routerBB9298] [IKE] INFO:  Received attribute type "ISAKMP_CFG_REQUEST" from 46.135.70.24[32684]
Thu May 08 08:10:06 2014 (GMT +0100): [routerBB9298] [IKE] ERROR:  Local configuration for 46.135.70.24[32684] does not have mode config
Thu May 08 08:10:06 2014 (GMT +0100): [routerBB9298] [IKE] WARNING:  Ignored attribute 28678
Thu May 08 08:10:09 2014 (GMT +0100): [routerBB9298] [IKE] INFO:  Sending Informational Exchange: notify payload[10381]
Does anyone have idea what is wrong? What means this  Local configuration for 46.135.70.24[32684] does not have mode config?
View:
Selected IKE Policy View
General
Policy Namexxxxxxx
Direction / TypeBoth
Exchange ModeAggresive
Enable XAUTH Client
Local Identification
Identifier TypeFQDN
FQDNlocal.com
Peer IKE Identification
Identifier TypeFQDN
FQDNremote.com
IKE SA Parameters
Encryption Algorithm3DES
Authentication AlgorithmSHA-1
Authentication MethodPre-Shared Key
Pre-Shared Keyxxxxxxxx
Diffie-Hellman (DH) GroupGroup 2 (1024bit )
SA-Lifetime28800 Seconds
Thank you in advance
Peter
SamirD
Level 5
Level 5
I found that ipsec doesn't work because the IP of the phone is always changing. Try using the PPTP option and see if that works.
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
Hi Samir,
Yes pptp is no problem. But i wanted ipsec :(
Ipsec won't work because of the IP address issue.  Sorry. :(
