06-05-2013 05:50 AM
we have
1-A wireless link (pre-wimax) that provide me with 2 Mb internet connection (tagged Ethernet frames) throught RJ-45
2-have 6 real IP _one of them as Gateway
what i need now is what is the best and cheapest device to do NAT and DHCP to allow users to access the internet , i am trying to do this using Cisco AP 1141 and the link is working fine with static ip configuration on my lap (give my wireless NIC real IP) but now i just need device to do NAT and DHCP
my suggestion is can i use Cisco RV220W Wireless-N Network Security Firewall to do this function
is the WAN port on this router support tagged ethernet frames ??? or even untagged frames
and can i give this router one of those public IPs and give the rest of those IPs statically to other devices on the network
any help will be appreciated
06-05-2013 07:54 PM
Hi Mahmoud, the RV220W does not support tag ethernet frames on the WAN. The SRP500 series does.
-Tom
Please mark answered for helpful posts
06-06-2013 01:20 AM
Thanks Tom for your help
and kindly advice on those questions below and the below scenario
1- is the WAN port on this router support untagged ethernet frames ?
2- can i give this router WAN interface one of those public IPs and give the rest of those IPs statically to other devices on the network
WAN Interface to the pre-wimax device-----------2nd 10/100 port----------Router----------1st 10/100 port ------LAN interface users (DHCP )
NAT on router to translate from private IPs on LAN interface to public IPs on WAN interface
thanks in advance
06-06-2013 06:47 AM
Hi Mahmoud,
1- Yes, untagged ethernet frames are fine
2- Yes, the router supports one to one NAT and DMZ functions which allow this proposed set up
-Tom
06-11-2013 03:17 AM
Thanks Toms for your help and support
so the SRP521W can be suitable for this solution as i think
connect the pre-Wimax tagged ethernet cable RJ-45 to the WAN port and make this port tagged in this 802.1Q frames
and then do a DHCP pool for the private IPs on LAN ethernet ports and make a NAT translation from private IPs to Public IPs
is this correct??
Thanks in advance
