12-25-2013 02:58 AM
I have upgraded the router to your latest 1.1.1.06 firmware and after it reboots (which btw takes ages) it comes back with:
Critical failure. Please contact support.
Any idea on this? it is unusable now!?
Solved! Go to Solution.
12-25-2013 10:01 PM
Hi Walter
From your description, "Blinking green PWR LED and solid red DIAG LED is all I get", the device is still at boot loader phase. So you tried tftp method but doesn't work? Can you try again? you can use this tftp.exe (http://tftpd32.jounin.net/) to upload the firmware to 192.168.1.1. Below are some more details about the tftp upgrade.
1.power off
2.power on with pressing the reset button, wait for 10s, untill the diag LED turn red, and power LED keep flashing.
3.set lan pc to 192.168.1.100
4.use tftp client to put the firmware to device. Windows command for example: tftp -i 192.168.1.1 put RV32X_v1.1.1.06_20131206-code.bin. Or using other tftp client like "http://tftpd32.jounin.net/"
5.after tftp finish, the device will reboot by itself.
6.after startup, power led is on, diag led is off.
12-25-2013 05:14 AM
Hi Michiel
Please try below steps in case of firmware failure while not HW failure.
1.power off.
2.Keep pressing the reset button, then power on (keep pressing the reset button untill the diag LED flash)
3.Connect PC to LAN1 and set the PC to static address 192.168.1.100.
4.try to upload the firmware from the PC via tftp, for example,
tftp -i 192.168.1.1 put xxx.bin
BTW, can you check if the md5 of your firmware is "c808a5bfe08dc9dedc5786e738a36384"?
12-25-2013 05:49 AM
12-25-2013 10:59 AM
Thanks for the heads up on the new post Michiel. I too have an RV320 that has been bricked by this new firmware. Blinking green PWR LED and solid red DIAG LED is all I get. I've tried rebooting the router while holding reset so that I can upload the new firmware again via TFTP, but I can hold reset 'til I'm blue in the face while powering on and the router doesn't respond.
12-25-2013 11:01 AM
Yes I have exactly the same thing :( I wonder what we are supposed to do now and what Cisco is gonna do about it.
12-25-2013 06:08 PM
Hi Michiel and Walter
Please open a support case and let support team help you. BTW, Did you upgrade from 1.1.0.09 to 1.1.1.06? upgrade from LAN side PC or WAN side PC?
12-25-2013 09:55 PM
Zhaogiang,
Upgrade was from 1.1.0.09 to 1.1.1.06 and was done from computer on LAN side.
12-25-2013 10:01 PM
Hi Walter
1.power off
12-26-2013 03:38 AM
I actually have it working again That last method from Zhaogiang Wang did it
Thank you so much!
12-26-2013 05:40 AM
After trying this again and it failing to help I downloaded the TFTP client that Zhaogiang recomended and tried again... the router came back to life! There must be something wrong with the other TFTP client I was using.
Thanks Zhaogiang!
12-26-2013 06:00 AM
Thank you Michiel and Walter, good to know the steps fixed your devices.
10-13-2016 11:25 AM
Hi Zhaqiang,
The TFTP asked me a port from 192.168.1.1
But the default is 69 !!! is it good one, or which port that I have to put?
10-13-2016 06:05 PM
yes, default tftp port 69.
01-23-2017 07:14 AM
I suggest to put version of firmware: 1.2.1.14
10-28-2017 06:40 AM
my cisco rv325 all lan ports are not workng.
than how can i upload firmwae?
