RV320 specific websites timeout behind device
JeffBowles
I have been using an RV320 Gigabit Dual WAN VPN Router for several years now in a simple modem->router->switch configuration, and around the start of August I began noticing a few websites began timing out when I tried to access them.
For example, I cannot reach hivelocity.net (a dedicated server host) via HTTP any longer, though I was accessing it regularly before. It responds to ICMP traffic (ping, mtr/traceroute), and using nslookup I can verify DNS is responding properly.
# ping hivelocity.net
PING hivelocity.net (66.232.99.10) 56(84) bytes of data.
64 bytes from 66-232-99-10.static.hvvc.us (66.232.99.10): icmp_seq=1 ttl=56 time=147 ms
64 bytes from 66-232-99-10.static.hvvc.us (66.232.99.10): icmp_seq=2 ttl=56 time=82.8 ms
64 bytes from 66-232-99-10.static.hvvc.us (66.232.99.10): icmp_seq=3 ttl=56 time=82.8 ms
64 bytes from 66-232-99-10.static.hvvc.us (66.232.99.10): icmp_seq=4 ttl=56 time=83.3 ms
64 bytes from 66-232-99-10.static.hvvc.us (66.232.99.10): icmp_seq=5 ttl=56 time=78.0 ms
^C
--- hivelocity.net ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4002ms
rtt min/avg/max/mdev = 78.071/94.909/147.450/26.340 ms
Testing a telnet connection to port 80
# telnet google.ca 80
Trying 172.217.3.163...
Connected to google.ca.
Escape character is '^]'.
^C
Connection closed by foreign host.
# telnet hivelocity.net 80
Trying 66.232.99.10...
^C
Additionally, when I bypass the RV320 and connect directly to the modem I'm able to connect and load sites properly. I have also upgraded the firmware to the latest version, and have attempted both power cycling and a factory reset without success.
Has anyone run into something like this before? Or have any suggestions about how to debug further?
Thank you,
Jeff
raina
Any update on this? I am having the same issue and I do not know how to fix it.
SamirD
Level 5
Level 5
Super strange?  Have you run a traceroute to see where it is getting stopped?  I would compare trace routes with and without the cisco and see if they differ paths.
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
